Sorry, posted an old IC number from memory. The newer "Simple Switcher" VReg ICs are far more efficient and can boost better than the one I referenced.
Sorry, that's not correct. This is a switching mode power converter. It uses inductors and diodes to step down voltage very efficiently. I recommend you stick with the LM317T for now as it will be much easier to use. Find a 7V or so solar array rated at 1A to use it with.
