Jon Chandler
- Joined Jun 12, 2008
- 1,659
Solar panels produce their rated open circuit voltage and short circuit current with the rated amount of power. Where the load falls on the V-I curve determines the power output.
If I want to increase current I probably need to put some resistors in parallel. Now the question is do I need a higher rated resistor or lower rated resistor.Solar panels produce their rated open circuit voltage and short circuit current with the rated amount of power. Where the load falls on the V-I curve determines the power output.
Ok if you say so. I = v/r right So if I have extra V I should be able to increase I. I am pushing like 17v. So if r goes down I goes up parallel resistors do that right? The other way is what a transistor?Where will you connect resistors "to increase the current"? Series resistors reduce current and parallel resistors waste current.
You need bright continuous sunshine on the solar panels and have them face the sun to produce more current.
No not really (I assume) you kinda scanned the post. When I went back and looked another time during better light I got a better result sadly though I am still no where near the current I think the Laptop will need. For now the plan is to continue with the laptop but my expectations are to eventually abandon that and settle for a R-PI.I think he said that his solar panels are indoors behind a window and with no sunshine so the current is very low.
From what your telling me I will get a increase in amperage. That is good. however is there any formula that would allow me to estimate this? Managing expectations I don't expect to get 5 amps fom these little battery tinder solar panels even with a buck converter. It would be nice to know how much though. what I can do is wire up a couple extra cells my self and drop those into the mix if I am way to short. None the less you answered my most important question and gave me direction thank you.For a DC-DC converter: Power In = Power Out - switching / resistive losses.
By reducing the voltage at the output via a buck converter will yield an increase in available amperage at the output (ignoring losses).
Formula for using a buck converter in general (voltage source input) or using one with a solar panel? If the former case then you use the formula I presented but if you are talking about the latter it becomes more complicated because the nature of solar panels is such that the open circuit voltage and closed circuit amperage that you measure while unloaded will change as the panel is loaded. Like motors (inductive loads), solar panels have complicated characteristics that place them in a class of their own which requires unique analysis which is beyond my scope. As you may have noticed a solar panel will show a near full voltage in any light condition but will produce little to no current unless well lit. Plus a DC-DC converter needs some current of its own just to turn on.No not really (I assume) you kinda scanned the post. When I went back and looked another time during better light I got a better result sadly though I am still no where near the current I think the Laptop will need. For now the plan is to continue with the laptop but my expectations are to eventually abandon that and settle for a R-PI.
THE REAL POINT of this whole thing is a learning exercise for me. Basically I am going to create a renewable BMS system throght trial and error. I want to learn allot more about powering things with solar and wind etc. Thanks for the responses they have all been helpful.
Is there an approximation used to estimate the average power output of a panel over 24 hours / 365 days a year? Clearly it's dependent on latitude, cloud cover, angle of the sun from noon and snow coverage but I imagine someone has calculated the mean / median / mode of common consumer panels over lifetime. It seems the rated output as you described is a useless quantity most of the time as many users like myself have been woefully disappointed at the actual output over the coarse of the dayYou said you measured only 30mA from your two paralleled solar panels that are rated for a total of 13W at 12V which is 1.08A. That is 36 times lower than rated. You said "it is winter and the light was indirect".
The rated power from a solar panel is when it is with the sun directly above it (in the tropics where there is no winter), at noon and on a sunny day. Frequently a solar panel is turning and facing the sun all day but yours is on and behind a window and is not even pointing up.
In the morning, afternoon and night the battery powers the laptop then the solar panel power must be a lot more than double for the laptop to operate 24/7. Also, don't you have cloudy days with no sunshine?
If the laptop needs 19V then the 12V from the solar panels that drive the voltage stepup converter need their current increased 19V/12V= 1.6 times more plus even more current for efficiency losses.
I know your lying man I know you have the seceret to quantum power just tell the common folks the truth MAN. JK LOLThat point is the maximum power available to the DC-DC convertor × an efficieny of 75% – 85%. If you increase the voltage, the current available will be less. More current means less current. Power = volts × amps and there isn't any way to get more power out than you have to put in.
I have said this a few times now. This is an educational exercise. Its not that results oriented.Your results are obvious:
1) You have little solar panels in the dark producing almost no current.
2) You have an old lead-acid battery that was never upkept. A topping-up charge must be applied to the battery every 6 months but you did not do it so your battery is finished.
| Thread starter | Similar threads | Forum | Replies | Date |
Plug-in balcony solar... | Power Electronics | 15 | |
| K | Testing Ni-Cads used in solar lights | General Electronics Chat | 19 | |
Regarding WaveShare Solar Power Manager USB power charging IC CS8501 .#2 | Power Electronics | 0 | |
Balcony solar panels | Power Electronics | 36 | |
| G | Lithium / Lead acid solar powered chargers | Power Electronics | 9 |
