The method is only supposed to work in places where heat from the sunlight is a problem and people suffer from heat stroke.
Would i be able to find a solar panel under 3 ft to power it up?hi,
Check thru the 12V panel versions,
This one has the panel and controller, 12V rated.
https://www.ebay.co.uk/itm/80w-Sola...271751?hash=item35fe73d907:g:T3QAAOSwbwlXAoYL
It seems an expensive way of keeping cool..
E
Just a crazy off the wall thought - could you use a peltier module and cut out the "middle man". Or do you need to charge a battery to keep it going in the shade?Hi everybody,
I need a little help with choosing the right solar panel to run my miniature cooling unit. The total power required for it would be 74 watts and it's supposed to run for a good 5 hours. so that's around 0.35kWh worth of energy required. any recommendation on which solar panel i should use? also if need to run it on the battery what battery back it up for 5 hours? My size requirement for the solar panel is small as-well I do not need a panel bigger than 3 inches. I have attached the power budget in the thread
thanks!
I see from your first post this is a peltier unit ... and you are somewhere pretty hot , people in danger of heat stroke !!
From Wikipedia ....In refrigeration applications, thermoelectric junctions have about 1/4th the efficiency compared to conventional means (they offer around 10–15% efficiency of the ideal Carnot cyclerefrigerator, compared with 40–60% achieved by conventional compression-cycle systems....
A reasonable size AC unit in a moderately hot climate for one room is about 2.5Kw ...this is a compressor driven system , 4 times more effective than peltier ...so you need a 10KW peltier unit to have the same effect ..
You are trying to do this with 75W ..... Less than ONE Percent of what is needed
The only way you may notice some small effect is if the person was in a plastic bubble
Look into evaporative cooling .
I presented this idea several times but my professor doesn't want to listen. IDK why he wants me to do it this way.hi Hassan,
If I was making this project I would consider stripping down and reworking a 12V compressor mini fridge..
I would not consider the Peltier option, very inefficient.
E
Insulation is crucial. 12 cubic feet strikes me as huge for a peltier project. A white or reflective surface will help as well.My initial thought was to use an evaporative cooler and i did my working on that as well but as far as it stands now i have to use the Peltier cooler to cool down a small 3ftx2ftx2ft box. any help on the solar panel? It needs to fix on top of the box
Plug-in balcony solar... | Power Electronics | 11 | |
| K | Testing Ni-Cads used in solar lights | General Electronics Chat | 19 | |
Regarding WaveShare Solar Power Manager USB power charging IC CS8501 .#2 | Power Electronics | 0 | |
Balcony solar panels | Power Electronics | 33 | |
| G | Lithium / Lead acid solar powered chargers | Power Electronics | 9 |
