what would be the wattage of a 20x20 cm solar panel if the efficiency is 44% instead of 5%
A 100 W solar panel is a 100 W solar panel, efficiency is "another number". it doesn't matter if it's 100% efficient or 1% efficient.what would be the wattage of a 20x20 cm solar panel if the efficiency is 44% instead of 5%
you have been reported. now if someday you can change the rules to accomodate your view of how things should be, until then, keep away.Google and all other search engines not working today?![]()
you have problem understanding basic solar electronics, that is your problem. see reply by bernard, that person understood the OP perfectly and calculated based on watt per square centimeter based on efficiency.A 100 W solar panel is a 100 W solar panel, efficiency is "another number". it doesn't matter if it's 100% efficient or 1% efficient.
Is that what you were asking with different initial and final numbers?GaAs is the highest performance solar material currently available, boasting conversion efficiencies in excess of 40%, nearly double those of crystalline silicon. This means that it can produce nearly twice as much power in a given surface area.
Hi there,what would be the wattage of a 20x20 cm solar panel if the efficiency is 44% instead of 5%
