Thanks for that, it makes sense.Never sized a solar panel, but worked in the industry (basic research). I did tell a local manufacturer that they sized an array wrong for a particular inverter and that's why the system was for show and never worked.
I did design a system to do a demand side management study for that same installation hence the troubleshooting of the inverter. I didn't build or operate the system. I just designed it in a big hurry. The published study was done remotely, pre-internet.
Yes, the standard is AM (Air Mass)1.5 Global spectrum. https://en.wikipedia.org/wiki/Air_mass_(solar_energy) 100 mW/sqcm or 1000 W/m Clear day around noon in most places. Short circuit current is proportional to intensity,
OK, your right, crap shoot. You need a calculator e.g. http://solarelectricityhandbook.com/solar-irradiance.html
which can tell you on average how much solar energy your panel should get per day based on location, direction and angle of the panel.
Using the calculator theoretically the 100 Watt panel I was considering would do the job if
1. it was a genuine 100 watts output. The panel dimensions work out to about that so it might be OK.
2. I had some sort of battery storage to extend the usage during daylight as there would be an excess of power at midday and not enough in the late afternoon.
Interesting...
Maybe I will an consider battery storage upgrade at a later date.
