solar panel reverse polarity protection issue
amitele
Joined Jul 30, 2016
21
Does solar panel too requires reverse polarity protection OR reverse polarity protection is only required in case of battery???
I tried to explore internet and gone through various post but nowhere i found Reverse polarity protection for solar panel, instead i got reverse current flow to solar panel protection using MOSFET at panel side. It may be possible that same MOSFET might be protecting from reverse polarity too along with reverse current flow protection to solar panel but i am NOT sure.
But i am sure that the MOSFET used is for reverse current protection.
Do i require extra MOSFET for reverse polarity protection of solar panel or the same MOSFET Q1 will do the job.
Please find the attachment. You will find MOSFET Q1 at right corner.
Can anyone guide me on this.??? It is really important to me.
Thank you..!!!
dl324
Joined Mar 30, 2015
18,521
I can't tell what you're trying to protect from reversed connections. Post a schematic of the power connections.
amitele
Joined Jul 30, 2016
21
Even it happen one time, controller or less likely Panel is gone and damage is done. Moreover, if under maintenance it may require to re assemble.
wayneh
Joined Sep 9, 2010
18,184
If there is no other current source, there is nothing to protect the panel from.
Are you asking about protecting the panel from reverse current from the battery, in the dark. Or are you asking about protection from hooking up the panel incorrectly to the circuit?
amitele
Joined Jul 30, 2016
21
i am asking about protection from hooking up the panel incorrectly to the circuit. There is other current source in the system (Battery)
ErnieM
Joined Apr 24, 2011
8,415
I would first recommend proper distinctive color coding and labeling to guide the technician to do the work properly in the first place.
If I continue to hire incompetent workers the next thing to do is add either a MOSFET or diode.
JUNELER
Joined Jul 13, 2015
183
I look the drawing ,are you using a battery or another power source. can i know from you the level
of battery voltage you are using,is it 9v or 12v. What input do want to protect, Vin,Vcc .
amitele
Joined Jul 30, 2016
21
12 volt battery and i want to isolate circuit in case of reverse panel voltage
