Hi, sorry to wake up this post, but I think that is better than open another one again.
I have simulated this circuit in MultiSim. The project is a litller solar panel (6V 100mA), a Li-Ion battery (3.7V nominal, 4.2V max) and a load.
In this circuit, I have only simulated how I could disconnect the solar panel when the battery goes up 4V, and then,, reconnect it again when battery's voltage goes down to 3.6V.
In this case, the variable voltage source is the source panel, and "load 100ohm" is simulating the battery.
As you know, the battery voltage and solar panel voltage will be the same(minus schottky diode).
If you go up in voltage controlled source until you get Vref = 2.5 in TL431, you will disconnect the battery with the 2n7000 mosfet. R11 mades the neccesary hysteresis and then, when battery's voltage goes low (due to the real load consumption) to 3.6V, the TL431 will reconnect again the mosfet and the battery will be charger again.
Please, experts !!!!
do you find anything wrong here??? Or probably all of it is wrong ?
NOTE: I know that TL431 is able to conduct until 100mA, but for this exercise I prefer to use a mosfet. Also I don't know if only with the TL431 and without mosfet I will be able to manage to get some kind of hysteresis.
After this circuit is correct for you, I have to desing a little one with TL431 to disconnect the load from battery if it goes down 3.2V and reconnect load again (hysteresis) when battery goes up to 3.6 or 3.7
Please, help me and comment this circuit.
Regards
Mod edit: new thread created.
Regards
