solar and clips matter
Mussharraf Hossen Shoikot
Joined Jul 28, 2017
24
if i attach one solar panel to a battery terminal pair using alligator clip and then attach another solar panel to the terminal pair also, do the watts of the two solar panels add up as in solar 1+solar 2 watts? config is both panels are attached to the terminals using alligator clips and terminals are large enough to take in 2
xox
Joined Sep 8, 2017
936
No. Voltages in series add together, power is the product of the total voltage and current throughput.
EDIT: You need to post a drawing or schematic. It isn't entirely clear whether you're connecting these in series or parallel.
AlbertHall
Joined Jun 4, 2014
12,663
It sounds like the two panels are being connected in parallel across the battery, which I think would be fine and result in the currents from the two panels adding to make the battery charging current.
