SMPS design
Muguai678
Joined Mar 7, 2024
I am designing a 30w smps using transistors only in the oscillator circuit that generates the pwm and the switching transistors: which are the best option transistors to use
AnalogKid
Joined Aug 1, 2013
12,276
Is this school work?
Also, please post your schematic. Paraphrasing Rear Admiral Joshua Painter,
"Engineers don't take a dump, son, without a schematic."
ak
ronsimpson
Joined Oct 7, 2019
4,812
No one makes a PWM using transistors. We did 40 years ago. There are ICs that do the job.
I would use transistors like the 2N2222A. Years ago I used 2N3904 and 2N3907.
Sounds like a school project. Divide up the PWM into pieces and try to make each one. Can you make a simple oscillator? comparator? op-amp?
