Hi all
I want to design charger with smps transformer
I will use tl494 for pwm and mosfet driver for primary side of transformer for range 150 to 240 v AC
I have some questions here , in secondary side I will get constant voltage let say 14.5 volt to charge 12 volt battery,this method use feedback from output voltage
As i know 12 volt charger output over 14 volt then after connect to battery it will decrease depend on battery voltage, and increase constantly to 14.7 then the charger will disconnect (I assume one stage charger)
here i'm confusing if I used feedback from output the pwm will set to pulse width that output 14.5 ,it's mean feedback will compensate drop voltage
I asked to use correct feedback for smps charger?????
i want to ask if i made isolated auxiliary turns on transformer and set it to fixed voltage let's say 5 volt ,then use high ampere secondary for charging ,did the voltage on load drop in each output?
