SMD resistor reactance
toughspeaker
Joined Jan 28, 2009
40
Hi boys and girls!
In RF electronics, not only capacitances and impedances can change with temperature, time etc, but also resistances. As a rule of thumb, engineers do not use carbon film resistors but rather metal film etc.
Now my problem is that i have a batch of smd resistors that i would like to test their reactance on.
How do one know if a smd resistor is carbon film or metal film? How can one test the reactance of the smd resistor in a reliable way?
Any help would be appriciated.
toughspeaker
Joined Jan 28, 2009
40
Thanks Bertus! A very informative link.
So this means that one should use as small SMD resistances as possible and that there is no simple way to check the reactance of the SMD resistor other than empirically by building the resistor into the circuit and hope for the best?
bertus
Joined Apr 5, 2008
22,988
The influence of the inductance and capacitance of the resistor is depended on the frequency of use.
At very high frequencies (above 100 MHz ) the influence will rise.
I think the attached PDF will give you even more info.
Ghar
Joined Mar 8, 2010
655
The inductance and capacitance of a resistor will be influenced by the PCB layout you use, probably more so than whatever the resistor contributes itself.
Wendy
Joined Mar 24, 2008
23,805
A long while back I had to build a M derived filter for work. I had access to both SMT and through hole components, so I build both, then tested them. The rolloff freq was somewhere in the neighborhood of 130Mhz I think. The curves were identical except the notch, the SMD version had a 10db better rejection than the through hole version.
toughspeaker
Joined Jan 28, 2009
40
Wow Bill! Increadible! Now, would you mind telling me a bit more about that experiment of yours? the through hole resistors, were they carbon- or metal film based? Which size were your SMD components 1206, 0805 or 0402?
Thanks for all inputs!
Wendy
Joined Mar 24, 2008
23,805
That I can't answer, these were standard parts for our shop, I just snagged some and made it. A M derived filter doesn't use resistors per se, except for the terminations. My point is the worst SMT will beat a through hole version, since the parasitics are drastically reduced.
