SMD Component identification
qitara
Joined Jan 18, 2013
112
Hi
I need some help to identify what component this is in the picture. Google does not bring up anything.
SamR
Joined Mar 19, 2019
5,487
Lot's of various NP devices but I'd go with diode to start with even though lacking the polarity band...
qitara
Joined Jan 18, 2013
112
Thanks for the info gents.
The diode is shorted so i need to replace it, problem is that i don't have an exact replacement. Would there be any issues if i use any random diode with the same voltage and current ratings ?.
qitara
Joined Jan 18, 2013
112
Is there a chance the diode could be something else ?, because i got a couple other of these on the board and i took one of to measure with diode check but it only shows open circuit. Any ideas ?.
SamR
Joined Mar 19, 2019
5,487
Did you check it in both directions? With a meter in diode test mode to overcome the ~0.7V drop across it?
