MisterBill2
- Joined Jan 23, 2018
- 28,462
The fact is that both kinds of those sensors require constant power to function, no matter how it is supplied.And for a battery powered remote sensor part of a home security system, battery life matters.There are two types of Hall sensors, two wire & three wire, the three wire versions are intended to switch a load, The two wire are intended for higher impendence sensing, IOW the pair carry the supply as well as indicate the status of the device.
e.g. input into a PLC or Microchip for instance.
