ebeowulf17
- Joined Aug 12, 2014
- 3,307
I believe that in most home coffee makers, the expansion of water/steam as a result of heating is used to push the water from the bottom of the machine up to the top. The place where water is boiling is significantly above local atmospheric pressure - the pressure where water is heating is determined in part by the weight of the water above it and by any flow restrictions which slow that water down as it tries to make its way towards the bed of coffee grounds. I don't have any hard data, and perhaps I'm overestimating these effects, but I think the water boils at a higher temperature than your elevation would lead you to believe.But water boils at different temperatures. At my elevation water boils at 203.4˚ F. The sensor can not heat enough to make the pot think it needs to be cleaned.
It sounds like temperature, not time, is the determining factor in this system, so the small differences in voltage shouldn't impact performance of the cleaning light system.And if you consider the possibility of using a time base to measure how fast water boils, in America, some homes are running close to 110 VAC at the outlet while others (some of the places I've been) can measure 119 VAC. Given the difference in voltages, the wattages will vary enough to cause the so called sensors problems deciphering when it's time to be cleaned.
Sorry, just having a hard time believing there's a simple way for a pot to know when it's time to be cleaned.
