small ac to dc voltage follower
RPLaJeunesse
Joined Jul 29, 2018
264
I see the schematics looks fine, just one thing is not clear to me. The output of peak detector will keep the voltage high - if the input goes low, capacitor will still keep the higher voltage as peek detector does. Who discharge the capacitor to measure lower voltage then ?
In the video's schematic R11 and R12 combine to discharge capacitor C3 down towards ground with a 1.5 second time constant. It will not get to ground as U1B will not let it go below the Vref voltage of about 0.8V. (With no input signal R1 also discharges C3 some as well, so its more like 1.3 seconds time constant, and maybe about 1 second for the final output to go from full scale to zero.)
38,576
Still say a precision full-wave rectifier would likely be the best for you needs.
If you answer my questions in post #26 I can give you a circuit example.
Sensacell
Joined Jun 19, 2012
3,786
The circuit shown in the video IS a precision rectifier and peak detector.
It uses a virtual ground to allow handling the bipolar input signal, then uses a differential amp to remove the ground offset- resulting in a 0 referenced positive DC output.
alfak20
Joined Sep 30, 2010
10
So what's the impedance of the coil?
What power supply voltages do you have available?
How fast does the circuit need to respond?
A precision rectifier circuit should do what you want.
I don't know inductance of the secondary coil. The voltage at secondary does not change very fast lets say can be in 3-4 seconds. I have 24VDC, 5VDC - whatever I can provide them but I prefer 5VDC.
38,576
[/QUOTE]
Okay.
I didn't watch the video because I don't have the patience.
But I prefer to average a precision rectifier signal rather than use a peak detector, since it is less sensitive to noise and distortion on the signal.
Do you know it's approximate resistance?
alfak20
Joined Sep 30, 2010
10
Ok, I see now and C3 must be adjusted according to input signal - how fast he changes his amplitude , I suppose 10uF will be ok. Anyhow I must try all that staff in the field. Thanks for all your suggestions !
