Thanks Matt, as the thread was progressing it was unclear to me.
Knowing that makes a BIG difference to the people responding to your thread.
You have been given three solutions and there are more.
Max and Gopher's solution with the 555 timer is a hybrid solution. Using analog and digital techniques.
If you want to get your feet wet, I would recommend this. Low cost, but some study time.
Mike's solution is digital and will give you absolute, adjustable control. It's low cost too, but along with electronic study, it will require some programming. If you want to go full bore on this stuff, Mike can make it seem easy. That's probably because he's already done everything wrong. At least that's the only way things get easy for me.
Colin's solution is analog, simple, fast and very cheap. You should be able to get all parts you don't have with a few minutes drive. This should have the advantage with battery power. But like everything else, if you want to know how it works, it will take some study also.
Good luck with your project.
