Hi and a Happy New Year to all
For context, electronics are currently somewhat above my pay grade (working on it), so my flagrant use of some electronics terms does not reflect my understanding of the subject. That said, I'm ready and willing to be educated.
Attached is a section of a larger schematic but thought it best to isolate the part I am trying to 'fix'.
Q1 (a 2N3906 PNP) is acting as a high side switch for the 'load' SW1 (there is an op-amp that measures the switch resistance/voltage as it opens).
Q1 base is controlled by U1 which results in a very fast saturation and de-saturation. I would like to slow the saturation (ie when the SN7407 effectively brings Q1 base to GND) while retaining the fast de-saturation. The timing does not need to be particularly precise - approx 20us of rise time would give the op-amp time to do its thing - this could be longer but probably not shorter.
My limited understanding has of course convinced me this is possible with a capacitor/diode/resistor combination but I'm struggling to build a circuit that does it - although I can do the opposite quite easily (a small capacitor between Q1 base and GND)!
Any help or advice would be very much appreciated.
Philip
Philip
