Slide Potentiometer
RdAdr
Joined May 19, 2013
214
According to your schematic, the voltage can vary between Vcc/6 and Vcc.
As said, the MCU will load the voltage divider quit a bit.
You could use a voltage follower between the voltage divider and the MCU input to aviod this.
Bertus
Why it will load it?
ericgibbs
Joined Jan 29, 2010
21,651
hi Rd,
This is a simulation I did for an OP sometime ago.
Its for a PIC, but it will give you an idea on how the source resistance on the input to a PIC's ADC has an effect on the accuracy of sampling.
The source resistance is stepped from 1R thru 12k5 Ohms, in 2k5 steps.
Note also the effect of the Taq and sample time .
E
