hi all i have this skytronic lab psu(linear),it was brought faulty,on powering it up voltage displayed about 50v,I found the coarse voltage controll pot busted off the pcb so assumed the psu had been dropped,i replaced it with a 10k,then the relays buzzed loudly,as i alterd the volage pots,long story short,i found 1 of 8 rectifier diodes shorted and a tap switching relay with welded contacts,i replaced the relay and diode,then it worked but would only output about 2a max,i since found 2 more diodes s/c,i could do with a schematic if anyone can help,i have replaced the diodes but have not put it together yet,but suspect it will fry the replacements,all pass transistors are ok+ the driver,its a 0-30v 5 amp psu,see pics.
