Single wire resistance cruise to "analog" multiple outputs HELP
xx_ED_xx
Joined Jan 22, 2025
28,240
OK, and welcome to AAC!
I think that what the goal is will provide a different voltage for each of the commands. If the voltage required is not specific, the method is very simple: Just add a resistor, perhaps 1000 ohms and five watts, from wire #1884 to the 12 volt system common, also called ground. There will be a different voltage for each of the four conditions: Off, On, Accel, Decell. Depending on the resistors in the control portion above, the added resistor value may need to be larger or not.
