Single phase motor to a reversing contactor
carlisleworks
Joined Jun 9, 2015
3
I am trying to wire a single phase motor to a reversing contactor. the incoming power is 115VAC, my control circut is 24VAC. i understand the control part of it but what im trying to figure out is how to wire the motor to the contactor so as to reverse direction of the motor. the motor has 6 leads. a picture is attached. i do know that T5 and T8 need to swap to reverse direction, but im lost as to how to tie it into the contactor. please help guys
strantor
Joined Oct 3, 2010
6,875
You could try the below diagram:
(NOTE1: wire colors shown, are only shown for clarity. They do NOT reflect actual wire colors in the motor. Pay attention to terminal NUMBERS only)
(NOTE2: This wiring scheme leaves voltage on the motor windings always. This is not really kosher, but given your contactors have NC contacts, it's the only option I see for what you have on hand.)
You really should get new contactors that have Normally Open (NO) aux contacts and wire it properly so that all lines are interrupted, like this:
P.S. the wiring diagram for your motor is found here:
https://www.baldorvip.com/servlet/productInfoPacket/VL1304.pdf
strantor
Joined Oct 3, 2010
6,875
I don't know how to tell you how to see something when it's already right there drawn out.
"look again," maybe?
"trace out each wire?"
</sarcasm>
Try this (in the first diagram; black is neutral (N) and line voltage (L) is blue :
Follow T5 (purple wire) upwards through the left contactor. - see it goes to N, which is connected to 1 & 3.
Follow T8 (orange wire) upwards through the left contactor. - see it goes to L, which goes back down through the contactor and is connected to 2 & 4.
so when the left contactor actuates, N connects to 1, 3, and 5 and L connects to 2, 4, and 8.
Follow T5 (purple wire) upwards through the right contactor. - see it goes to L, which goes back down through the contactor and is connected to 2 & 4.
Follow T8 (orange wire) upwards through the right contactor. - see it goes to N, which is connected to 1 & 3.
so when the right contactor actuates, N connects to 1, 3, and 8 and L connects to 2, 4, and 5.
Left: L = 2,4,8 N = 1,3,5
Right: L = 2,4,5 N = 1,3,8
See the switch now?
This is very helpful. I don't see the NO contacts?
Thanks!
@strantor
30,807
Although reverser contactors have a mechanical interlock, they generally each use a N/C contacts for electrical interlock, by 'locking' out the opposite side coil.
Can you see them now? The second relay (contactor) is the same as the first.
This thread is about 3 1/2 years old.
Ron
So best is a 4 pole contacter with an auxiliary NC contact on the overload for interlock?
30,807
Typically O/L's vary, some disconnect the 3ph power others also achieve this through using the N.C. contact in the coil supply, they occasionally also have a N.O.
In the case of the N.O., I generally use these as some kind of indicator/annunciator or flag, and even an input into a PLC, if this is how the contactor is controlled.
Incidentally the O/L you see in the schematics is considered used on the wrong side of the coil now.
Thanks Max
Reloadron
Joined Jan 15, 2015
7,937
I am trying to use this reversing contactor to reverse a 1/2 Baldor preferably using 220V. Any insight?
https://www.amazon.com/dp/B004ZRO8SO?psc=1&ref=ppx_pop_dt_b_asin_title
Depends on the actual motor. Some motors are reversible and some not. Here is what I suggest, start a new thread of your own. With your opening post include all of the nameplate data of your motor, things like voltage, current, locked rotor current, On a single phase AC motor like a common off the shelf 1/2 HP Baldor they are not reversible. Seeing a link to the motor data sheet would really help getting you good help.
Ron
MisterBill2
Joined Jan 23, 2018
28,224
Ron
For a Baldor motor, you should be able to find the information on reversing it on the company website. amazon will only know shipping weight and price.
Reloadron
Joined Jan 15, 2015
7,937
Uh yes, however the link posted was for the reversing contactor from Amazon and not the motor. While I know your dislike for clicking links the only posted link is for the dual contactor. This is what the link was to:
I like these for the mechanical gang feature but I prefer the ones with a thermal overload feature. Anyway, the link to Amazon was for the contactor and not the motor or anything remotely like the motor.
Ron
