I am in a bind trying to wire some indicators. The input is singular and either +ve or -ve for L/R, it is also a momentary pulse (with a second input to cancel).There is a separate -ve feed to power the indicators. The control input cannot be altered so I have put some significant time in to figure out how to make this work with basic 12v circuitry.
Below is my best effort so far, in theory allowing the input to activate either the top or bottom bank of relays depending on polarity and be self sustaining until cancelled by the second input (C). I was confident in the operation of this until I realised the final relays would short together (thus activating both lights), I hastily added in diodes but am not confident in this. Not sure where to go from here, I may have over complicated it, or it may be impossible. I would appreciate some advice! Alternately advice on a component / circuitry that could do the job instead, simplest / most reliable solution is best.
Ideally the L input would cancel R etc, but not essential.
