Hello there, I'm new to AAC.
I'm working on an Iridium/GPS design and while trying to reduce components and size I found this antenna:
http://www.taoglas.com/product/cgip-25-4-a-02-gpsiridium-dual-band-patch-antenna-25254mm-2/
It's a dual band patch antenna with a single feed.
I'm not that experienced with RF and Antenna design and I wonder if I can use a singe patch antenna to feed both the Iridium system and the GPS system. If so, what are the considerations I need to have in order to have a successful design? At least impedance is the only thing that comes to my mind.
Thank you for your time and help.
Regards
Xavier
Regards
Xavier
