single ended amplifier circuit
ybababababsma
Joined Dec 2, 2010
1
Design a single ended amplifier circuit (single input, single output) with all the bias circuits using ltspice
to meet the following specification:
1) minimum DC gain is 4000
2) Total current withdrawn from power supply is 250mA
3) Vdd= 3.3 volts
4) Load capacitance is 250fF
5) maximum total on chip resistance (if needed) is 100Kohm
6) BW is to be maximized (ie not restriction on bandwidth)
7) no restriction on number of transistors used.
does anyone has a circuit i can use or show me how to do this ??
R!f@@
Joined Apr 2, 2009
10,014
Just tell us these
Who are you?
Where are u?
how old are u?
are u a male or a female?
and what does ur user name stands for?
thatoneguy
Joined Feb 19, 2009
6,359
Must be a very small input signal if DC Gain is 4k since you effectively have a 2 volt working window for input due to the supply.
Here is what I have a question about:
250mA draw with what, if any, input signal? What are the input/output impedance requirements.
