Sinewave Output Query
Juan_zero
Joined May 16, 2020
5
Obtain the output signal of the circuits in the figure, explain why this signal is obtained in each half cycle of the alternating current..
dl324
Joined Mar 30, 2015
18,453
What is your question? Am I correct to assume that this is school work?
You need to provide more information if you expect any help (signal amplitude for first picture, signal type and amplitude for the second).
Juan_zero
Joined May 16, 2020
5
you're right-....... explain why this signal is obtained in each half cycle of the alternating current..
Audioguru again
Joined Oct 21, 2019
6,826
The circuits are incomplete.
In the first circuit the signal source is not connected to ground.
In both circuits the oscilloscope is not connected to ground.
Then the scope will probably show only interference.
WBahn
Joined Mar 31, 2012
33,109
You still seem unclear on the concept. This is NOT the Homework Done For You Forum -- it is Homework HELP. Therefore YOU need to show YOUR best attempt to work YOUR homework. We can then HELP you get over specific obstacles you are encountering.
WBahn
Joined Mar 31, 2012
33,109
As with many simulators with graphical schematic capture, many parts have an inferred connection to Node 0. Notice in the left circuit that neither the source nor the scope have a pin that can be used to connect to ground -- it is internal.
