Sine wave oscillator with TL071 : How to modify the amplitude level ?
LowQCab
Joined Nov 6, 2012
5,102
A true, accurate, Sine-Wave-Oscillator is not a simple project.
First we need to know the intended end-usage of the Oscillator.
Does it need to create a very low-distortion, accurate Sine-Wave, or
simply a Waveform that's pretty close to a Sine-Wave ?
What Impedance must it be capable of driving ?
What type of Circuit will it be driving ?
What does the Peak-to-Peak Output-Voltage need to be ?,
Will the Frequency need to be adjustable, or fixed ?,
if adjustable Frequency, what is the Frequency-Range needed ?,
if fixed Frequency, what is the Frequency desired ?
Does the Frequency need to be accurate, and stable ?
What was the original purpose of building this Oscillator ?
sparky 1
Joined Nov 3, 2018
1,218
Getting the sine wave centered close to Zero.
You can think about that control adjustment as part of a split supply. Some designs have very finite adjustment.
This usually involves positive and negative voltage regulators. There are premade modules available.
I think by the time you get a single supply to be filtered, stable and get very close to zero that split supply may be a better option.
Philexium
Joined Oct 15, 2017
111
Good morning @LowQCab
Here are the answers :
1-Intended end-usage of the Oscillator :
- It is designed to make quench oscilltor for a superregenerative receiver I have already built
2 - Does it need to create a very low-distortion, accurate Sine-Wave, or
- As close as possible but not a low distorsion
3- What Impedance must it be capable of driving ? : I need to calculate it
4-What type of Circuit will it be driving ?
- See answer 1
5-What does the Peak-to-Peak Output-Voltage need to be ?
- Min. 0 to 3 Volts but I would like to test 0 - close to 9 V
6-Will the Frequency need to be adjustable, or fixed ?,
- Ideally from 30 kHz to about 150 kHz
7-Does the Frequency need to be accurate, and stable ?
- Not critical
8-What was the original purpose of building this Oscillator ?
- See answer 1
Again, thak you for your time and help !
Philippe
ericgibbs
Joined Jan 29, 2010
21,641
hi Phil.
Look at this Option uses a R2R OPA.
E
Added AD820 datasheet.
https://www.analog.com/en/products/ad820.html#product-discussions
Clip:
It has true single-supply capability, with an input voltage range extending below the negative rail, allowing the AD820 to accommodate input signals below ground in the single-supply mode. Output voltage swing extends to within 10 mV of each rail, providing the maximum output dynamic range.
Philexium
Joined Oct 15, 2017
111
I would like to clarify again one point :
I need the "bottom" of the sine wave to be at 0V, NOT centered at 0 V
Thank you !
Philexium
Joined Oct 15, 2017
111
hi,
Post #27 shows just that!
E
Good morning Eric !
Yes it's great !!!
I am sorry but the messages were crossed each other :)
I have to order some AD820 : a little bit expensive but those AD chips are very powerful !
I am eager to test it !
Thank you again for your time and LTSpice simulation.
Philippe
sparky 1
Joined Nov 3, 2018
1,218
OK SRR, NOT a supply issue and not a sine wave but an amplitude modulated signal. Approaching the threshold of thermal noise in a super regen used in an SRR receiver. An introduction Chapter 1.2 defines SRR and a successful electrical model shown in chapter 5 makes it possible to study the effects.
https://mobt3ath.com/uplode/books/book-77667.pdf
Describing thresholds in positive feedback and use of a square wave the article below says Despite the noise( in this case a screech ), A clean square wave is produced. (It is also the rate of sampling which is used for reshaping.) Shown in the next to last illustration and explained in the paragraph.
https://www.allaboutcircuits.com/textbook/semiconductors/chpt-8/positive-feedback/
AnalogKid
Joined Aug 1, 2013
12,294
OK, let's see if I have this correct.
You want to be able to vary the peak-to-peak amplitude of the generated sine wave (turn it up and down) , while keeping the negative peaks of the waveform at 0 V.
Yes / No - ?
If yes, that is not a simple thing to do. One approach would be a comparator/peak detector and/or integrator driving a DC-offset servo.
And - why? Why is it important that the negative peaks of the waveform sit at 0 V no matter what the amplitude?
ak
