Sine wave inverter DC-AC
LRG_HW
Joined Aug 29, 2017
Hi all,
I'm new to the forums and wanted to post my current project for feedback / advice.
I am using an ATmega644p to control the output of an MCP4902 2 channel 8 bit DAC via spi, which I am using each output channel to drive one half of a centre tapped transformer, see attached schematic.
So far everything is progressing, I have a slightly distorted output waveform from my transformer though so that is what I am currently investigating, see attached scope screenshot, the half wave if the - input to one of the op amps and the full wave is the transformer output.
Thanks for looking
Graham
wayneh
Joined Sep 9, 2010
18,184
I think you would have a hard time finding a piece of equipment that would not be happy with that waveform. It's not perfect but it's pretty good.
Have you looked at the waveform under load?
Audioguru
Joined Dec 20, 2007
11,248
Aren't you using Pulse-Width-Modulation? Your input signal to the opamp is not PWM because it has amplitude modulation.
An opamp is not fast enough for PWM anyway.
Maybe you are trying to feed a halfwave low frequency analog signal to the opamp? Then the amplifier will waste a lot of power making heat.
Here is a PWM waveform. The output devices switch completely on and completely off so they are never linear and do not waste power making heat:
LRG_HW
Joined Aug 29, 2017
Thank Audioguru, using PWM like that is something I had never thought about.
I shall look more into it as heat is becoming an issue already.
