I tried with diode output and it did not work.Hello,
As said, the outputs of the opamps can not be connected together.
If you want to continue to use the opamps , use diodes on the outputs.
You can configure AND and OR with the diodes as followed:
https://electronics.stackexchange.com/questions/131860/diode-logic-gates
Turn the diodes the other way round and connect R4 to +12V instead on 0V.I tried with diode output and it did not work.
