Simulation : Window Comparator help needed
OBW0549
Joined Mar 2, 2015
3,565
The LT1413 is a dual op amp, not a comparator. You cannot simply connect its outputs together as you would with an LM393 or other device having open-collector NPN outputs, because when one op amp is trying to output high and the other op amp is trying to output low there will be a conflict.
