bothHi 2034,
Welcome to AAC.
Which section of your TX and RX do want to simulate, or both.
E
Yes broHi 23
This is the RX section.
Do you follow it OK.?
E
BTW: Is this a Homework or College assignment?
Yes bro
Can you help me with TX section alsoHi 23
E
Post your best attempt of a simulation and then we can help you.
E
E
I have posted the circuit diagram in 1 st threadHi,
I use a different simulator, please post a circuit diagram
E.
Can you help me in finishing this simulationI have posted the circuit diagram in 1 st thread
Bro can you atach the simulation filesHi,
I have posted one version in post #4.
This is another version, can you explain to me how it works?
E
1. The PNP transistor is your project file is reversed.Can you help me in finishing this simulation
I opened the TS Proteus project file and the PNP transistor is not connected as you correctly show on your schematic.Hi eetech.
How is the PNP reversed?
Yes. And that will depend on the laser diode intensity, which is affected by the current flow thru it.If I understand correctly, the TS wants the buzzer to operate when the laser beam is broken, as shown in the simulation.?
E
Bro can you give me a simulation fileeI opened the TS Proteus project file and the PNP transistor is not connected as you correctly show on your schematic.
The emitter/collector are reversed.
The LD light intensity, focused on the LDR, determines the LDR resistance, which, in turn, determines when the transistor turns on/off the buzzer.
If all the TS wants is an on/off alarm simulation, just use a switch.
Can anyone attach the simulation fileI opened the TS Proteus project file and the PNP transistor is not connected as you correctly show on your schematic.
by Aaron Carman
by Duane Benson
by Jake Hertz
