Simulating laser diode driver circuit and ldr reciever circuit using proteus or any other simulation software
vasanth2304
Joined Mar 5, 2024
4
ckt2.png this is a security system when the laser beam is interrupted, ldr should detect and buzzer should ring. The second image is a laser diode driver circuit and the first one is ldr circuit. I tried simulating this in various softwares can someone help me simulating this
eetech00
Joined Jun 8, 2013
4,709
Can you help me in finishing this simulation
1. The PNP transistor is your project file is reversed.
2. For simulation purposes, If you want to control the LDR using input from the laser diode (LD), you'll need to couple the LD current with the LDR current based on a current transfer ratio that you determine.
ericgibbs
Joined Jan 29, 2010
21,466
Hi eetech.
How is the PNP reversed?
If I understand correctly, the TS wants the buzzer to operate when the laser beam is broken, as shown in the simulation.?
E
eetech00
Joined Jun 8, 2013
4,709
Hi eetech.
I opened the TS Proteus project file and the PNP transistor is not connected as you correctly show on your schematic.
The emitter/collector are reversed.
E
Yes. And that will depend on the laser diode intensity, which is affected by the current flow thru it.
The LD light intensity, focused on the LDR, determines the LDR resistance, which, in turn, determines when the transistor turns on/off the buzzer.
If all the TS wants is an on/off alarm simulation, just use a switch. :D
itskrish
Joined Mar 2, 2024
11
Bro can you give me a simulation filee
Can anyone attach the simulation file
To run the crct ckt
ericgibbs
Joined Jan 29, 2010
21,466
hi its,
It is AAC policy not to give final or complete answers to Homework assignments.
Only hints and/or guidance.
Moderation.
