simulate low temperature
superway
Joined Oct 19, 2009
125
I am looking for a circuitry that can simulate low temperature for battey's mat. This circuit can turn the heat on the mat when temparature is low. We used Freez-it bottle so far, but it is expensive.
Thanks in advanced
praondevou
Joined Jul 9, 2011
2,942
Thanks in advanced
If you have a compressor, you can use a vortex tube. Or you can wait until winter ;). Or you could use a peltier element attached to the sensor.
mcgyvr
Joined Oct 15, 2009
5,394
how low is low?
Buy a cheap refrigerator?
most proper thermal chambers use liquid nitrogen LN2 or liquid carbon dioxide LCO2 (use extreme caution)
32,840
Hopefully you are getting the idea that it is very hard to give a meaningful answer unless and until you give us some meaningful information to work from. Such as, what temperature range you are talking about, how long you want to hold it at that temperature, and how accurate you want that temperature to be, and perhaps some idea of how much energy is going to have to be pulled away from the object.
