I thought the pics from my phone would be better than this. oh well. The missing IC was the PIC, a 16f628a I believe and the 8 pin is a max627 dual power fet driver. I will try and draw out the circuit but sadly this was my last attempt and the most convoluted one, doh! It would be the only one I can find eh! The relay is meant to hold off the power to the fet until the PIC has initialized fully. The rest I just can't remember, had a family member ill for a time and had to shelve it but it may come back as I try to trace it out. Here are the pics.Yes, actual circuits or just pictures may help us figure out what is going on.
Another thing you could try is to run the motor in series with a 240V 100W lamp for a start. It probably will not drive much mechanical load but it will see if the motor works.
