Simple version of an internal op-amp circuit
Kartschu Weger
Joined Jan 20, 2019
I'm currently learning how op-amps and transistor circuits work and want to understand the simple version of an internal op-amp circuit. However, there are still some open questions.
Amplifier
The first stage here is a differential amplifier with R3 as the constant current sink. There may also be a transistor current sink or current mirror when I'm not wrong. T3 is a level-shifter (common-emitter, voltage-amplification). It receives a small current from the collector of T1, which is proportional to the input difference (U_pos minus U_neg), right? That means T3 creates an inverted voltage on its collector (output), which is proportional to that current. (I'm not exactly sure as T3 may also use the voltage from T1 collector?). However, why not using an NPN transistor? T4 is a common collector circuit that provides a small output resistance and amplifies the current (power-amplification).
Is my understanding correct?
The resistors I have used to simulate are not proper as the output gets into the negative saturation when I insert a small AC signal on the pos. Input. How can I calculate the resistors so that the output has a good range between Ub+ and Ub-? How can this circuit be improved (I'm aware of adding a better constant current sink made of a transistor)? I also saw some capacitors sometimes, would that help? Maybe a capacitor in front of T3 to remove offset?
Thank you!
ericgibbs
Joined Jan 29, 2010
21,463
hi KW,
Have you considered adding some negative feedback from the output back to the input, in order to 'fix' the Gain of the amplifier.?
E
Kartschu Weger
Joined Jan 20, 2019
hi KW,
E
Hey,
yes I'm aware that a negative feedbacks from the output to the inverting input would make it better in terms of Gain and linearity. However, this is more for educational purpose and I just want to know how the circuit above exactly works (what T3 and T4 exactly do, if T3 is driven by the output current or output voltage from T1, how to calculate resistors here etc).
ericgibbs
Joined Jan 29, 2010
21,463
hi KW,
As you are investigating the design of an OPA circuit, consider what the steady state Vout should be for a zero volt Input.??
Normally it should be zero volts Output for zero volts Input signal.
Your test design has negative steady state output voltage.
E
Veracohr
Joined Jan 3, 2011
783
With the circuit as-is, T3 is better as a PNP because the collector of T1 is centered at a positive average voltage. So a PNP helps move that average in the negative direction. You can get the output centered on 0V by just changing the value of R5.
Of course, the correct way is negative feedback, as already stated.
