Simple Temp Sensor Circuit using TMP36 and LM358
Audioguru again
Joined Oct 21, 2019
6,826
My computer and I have never seen an ods file type before. There are some converting to pdf programs available but they are a nuisance. Bertus, please can you post the list of opamps as a pdf file?
ericgibbs
Joined Jan 29, 2010
21,567
hi,
I have created the LTspice sim version, I will try that for you.
Will post the results
Why are you depressed, it will not help you solve a problem.;)
E
ericgibbs
Joined Jan 29, 2010
21,567
hi,
This shows the Temp function , it lights the LED at 50C.
Also note the Vbty is changing from 4.8v down to 3.6V and the 50C point is still OK.
E
Will look now at the Vbty function..
ericgibbs
Joined Jan 29, 2010
21,567
hi LL,
This shows the Low voltage part R7 should be a resistor and pot to enable a trim setting for 3.6v.
On this sim the Vbty falls from 4.8v to 3.5v to show the switch on LED at 3.6v.
E
R5 driving the TL 431 Vref is too low, you dont need 10mA, go for say 2mA, save your battery power.
ericgibbs
Joined Jan 29, 2010
21,567
Lucky-Luka
Joined Mar 28, 2019
181
Hi LL,
Look at R7 value, change R7 into series a 75K fixed and a 50k Trim pot, you can trim to the exact 3.6Vbty setting.
E
For convergence, try a different type of low power OPA in your simulation
Update;
Check this link, others have convergence problems with that OPA.
https://www.google.com/search?client=firefox-b-d&q=mcp602+ltspice+model
Interesting!
Any suggestion for an alternative rail to rail op amp easy to find for this little project?
Using LM6132 the simulation works correctly but I've notice that the price of that IC is too high.
Maybe mcp602 in real life will work just fine.
38,797
It likely will.
An LMC6484A should also work.
In your simulation, trying changing some of the simulation parameters to see if that eliminates the non-convergence problem.
Try using The Skip Initial operating point solution option (below):
Or try using the Gear Integration method instead of modified trap (below):
