Simple SMPS feedback error amplifier?
eem2am
Joined Jul 22, 2012
40
You have type 1, 2 & 3 error amps for SMPS feedback compensation...
But what is the error amp called that is just a high gain inverting amp?...ie, not an integrating error amp.
Also, can you confirm, that using this (unknown name) error amplifer, there is no gaurantee in eg a Buck battery charger that you would reduce the chances of instability, by using it, instead of a type 1, 2 or 3 error amp?
38,946
A SMPS that uses linear feedback will not be stable without compensation in the feedback error amplifier.
The inductor in the output causes a phase-shift in the feedback voltage that otherwise will cause instability or oscillation.
One exception is a hysteretic type (bang-bang) SMPS which does not require compensation since it does not use linear feedback, but has a comparator for feedback.
They tend to have more ripple in the output voltage, but that's usually not a problem for applications like powering digital circuits or battery charging.
The simulation of a simple buck regulator example is below:
eem2am
Joined Jul 22, 2012
40
Thanks, but i believe you are aware that current mode control gets rid of the output pole caused by the output inductor...it cancels it out.
What i am asking is how , generally, does an inv amp error amp compare with a type 1,2 or 3 error amp for stability?...better or worse?
