Simple Sawtooth Oscillator circuit help.
KyxeMusic
Joined Nov 9, 2017
I have done and tested this circuit design on the breadboard and It works fine.
https://gyazo.com/1717d6d8fef5ccb8b7f1ca640ec17742
The Potentiometer changes the frequency of the oscillation, thus changing the pitch of the audio output.
However, I would like to add another potentiometer that will change the Amplitude of the oscillation (a volume knob). How would I have to add the potentiometer to the circuit?
PD: The Input voltage is actually 19V, not 9V
dl324
Joined Mar 30, 2015
18,469
Welcome to AAC!
Circuit in question:
If you want to decrease volume, use a pot and put a voltage divider on the output. If you want to increase amplitude, you need to add an amplifier.
