Simple sawtooth generator schematic simulation question
Jony130
Joined Feb 17, 2009
5,601
The initial condition is the problem. Try to use this ".tran 0.1 startup" (start external DC supply voltage at 0V this box must be checked )
Lucky-Luka
Joined Mar 28, 2019
181
Thanks.
I've tried to play with the passives values and I obtained max 2kHz freq signal.
Do you think that using this circuit I can obtain a 70kHz signal?
38,871
what do you think is the reason for the distortion at low voltage?
If you mean the sawtooth flat bottom, that's due to saturation delay (time to come out of saturation) in the two transistors that discharge the capacitor.
General purpose transistors can have a significant delay (often more than a microsecond).
If you change to switching transistors with low delay, such as a 2N2369 for Q1 and 2N5771 for Q3, that will largely disappear.
Switching transistors can often be recognized by their relatively low max Vceo ratings (here they are both 15V), but you need to look at their data sheets to determine that for certain.
Lucky-Luka
Joined Mar 28, 2019
181
Thanks!
If I wanted the waveform to reach 0V I would have to use mosfets right?
38,871
Not necessarily.
You would have to use a different circuit.
Most of the observed voltage above 0V (about 0.8V) is due to Q3's Vbe (base-emitter) voltage, not its saturation voltage.
Why do you want 0V?
How close to zero do you need?
Adding a transistor to help discharge the cap gets it down to a little over 100mV (below).
38,871
This circuit is for a friend of mine that asked me it as part of a class D amplifier.
So it's for the PWM modulator I assume.
For that, the sawtooth doesn't need to go to 0V, you can just offset the audio modulation signal DC value to the middle of the sawtooth that goes to the comparator to give a 50% duty-cycle with zero AC modulation signal, which is the usual design goal.
