there are 2 batteries each severs different loads across fuse boxes. - the backlight would operate from the ACC, however load on/from the switches are dependent on the the fuses supply of power, which are constant power. But of course only send power the load device when switched.Can you give us a basic diagram of what you're working with?
Here's what you've given us to work with (in part; post #6)
As I understand it, ACC is active when the key is in an ON position. From what you just said
I must admit being confused.
If you have constant power (unswitched) from the battery then wouldn't you have a condition where your LED's are on all the time? This is why we need a drawing of what you are attempting to accomplish. Even if you have to scribble something on a piece of paper and take a picture of it and post it - at least we have somewhere to start from.
backlight would be from the Acc power whilst dimmer circuit would be dependent upon lights (on/off)
