You can also delay the output of the gate, which is what my circuit in post #10 does.So really, all he needs to do is delay the transmittal of the inputs. Hold them low for one (assumed) second.
If you want to delay power to the relay board, I think my circuit from post #12 would probably work for that.I thought that the delay to vcc is because there will be only one circuit as I mentioned in my first post.
but delay to inputs or outputs of the ic require four circuits for that i have no place on the board.
I am thinking to delay the power to the relay instead of IC.View attachment 161025
If they are active LOW, the sensible thing to do is probably to replace the 4070 with a 4093 and use them properly as NAND gates with the second input of each gate to a common delay circuit requiring nothing more than one capacitor and one resistor (and a diode if rapid reset is required). If they are active HIGH then a NOR gate (negative input AND) is required with a delay circuit configured slightly differently.
