Simple question on a symbol in schematic
Meycom
Joined Oct 19, 2015
4
I am a novice electronics tech and have encountered a symbol I cannot identify on a schematic for an audio mixer.
It's an upside down triangle with a squiggly line similar to a reversed S sideways?..
Any ideas?
Jeff
GS3
Joined Sep 21, 2007
408
You can take the image, upload it to Google Image search and it will find similar images and even guess what it is.
kubeek
Joined Sep 20, 2005
5,796
I guess there are more than one symbol like that in the schematic, then I think all should be connected together.
GS3
Joined Sep 21, 2007
408
The triangle is an earth or ground. The fact that it has the alternating symbol added makes me think it is the gnd of the AC side of a power supply or other circuit which has a separate DC side gnd.
30,681
It appears to be a non-standard earth ground symbol, possibly the grounded neutral, and used due to the general prevalent misuse of the earth ground symbol for circuit common.
12,145
In an audio mixer, probably an analog ground, as opposed to a digital ground. For noise control, ground currents from the analog amplifiers is kept separate from the ground current for the digital control logic circuits.
