simple question 230v to 12v 50w/5a timed output
teeach
Joined Oct 19, 2017
know a lil about electronics and electrical just want to make sure i'm not being a dummy or if there are any other better alternatives.
Problem:
A timed output circuit has gone bang on an piece of work equipment, wont go into detail as it may confuse the situation but it all works apart form the timed lamp button, I can see components on the lamp circuit disintegrated etc...
So I wish to make the lamp part sort of stand alone.
plan is to convert a 230v suply down to 12v 5a as the lamp it needs to power is 50w.
Resolution:
I was going to get this
https://www.amazon.co.uk/200-250V-Halogen-Light-Electronic-Transformer/dp/B00CXK30UW
and
http://www.ebay.co.uk/itm/DC-5V-12V...-Time-Delay-Relay-ON-OFF-Module-/192106941494
buBild accordingly and place in a project box with a push button on the project box also.
Can anyone see any issues with this?
any alternatives?
Dodgydave
Joined Jun 22, 2012
11,395
The Ebay timer pcb will do fine, giving you a time range you need, if you just want to put the light on and off manually then all you need is a 12V 5amp psu and a switch.
