simple clamp circuit resistor calculation
khatus
Joined Jul 2, 2018
115
Hello guys i want to calculate the resistor R in this circuit.Can anybody help me?
The value of zener diode(VZ)=4.8 volt.
well i try to simplify it
My question is is my solution is right??If not then what will be the value of R?
ericgibbs
Joined Jan 29, 2010
21,629
hi k,
This looks like a College problem assignment, can you confirm.??
Moderation moved to Homework.
kubeek
Joined Sep 20, 2005
5,796
That resistor is there only to ensure that the leakage current of the zener doesn´t go through the BE junction when the zener is below its rated voltage drop.
A zener´s voltage is usually specified at 5mA, so I would choose a resistor R=0.7V/1mA=140 ohms or higher, but higher resistor will make the zener react at a little bit lower voltage.
