Thank you, will change inductor and make changes.. didn't pay attention to voltage source sadly. trying shortly but why did you do 2000/31.4? thinking should be doing parallel combination but okay : learning more today : question getting more stupidYour load (R2) is 2k. Reactance of L1 is 628Ω.
But for frequency stability and for reliable excitation
reactance of L1 should be lower as much as possible than R2.
Selected 50 nH has reactance 31.4Ω.
So 2000 / 31.4 ≈ 64.
Pay attention to value of V1 in circuit right to green curve.
It is 12V.
These resistor and capacitor are important in real circuit, but not necessary for simulation.
With changed values of capacitors C3, C4 feedback power goes to emitter is not enough for oscillation.
Circuit works with capacitor C4=1μF, but it takes about 10ms for beginning oscillation,
because of long charging time through resistor R5 51k.
Below see reliable and frequency stable circuit, which works with load 2k.
ThanksIn my example, I used the CQ1 parameter - the average transistor capacity on the collector side. The collector capacity of this transistor (from the spice model) is 4 pF at zero offset. In this generator, the voltage is greater than zero and the average collector capacity is accordingly smaller. I have set 3 pF, although this capacity is likely to be smaller. I also added the entire capacitance of the feedback capacitor to the total capacitance of the resonant circuit, although it is more correct to attach an equivalent capacitance equal to the capacitance of two consecutive capacitances. This would also reduce the total capacity of the resonant circuit by about 0.4 pF.
I have made a rough calculation of the inductance of the coil. I used COIL64 (Coil32) to calculate the coil. This is a good program (multilingual) and I suggest you use it. The result is a small coil of three turns. View attachment 191106
Missing a lot of things in understanding
and sorry but what's the CQ1 in the transistor as you say is different from feedback capacitor? how did you see it is 4pf at zero offset?
Maybe missing something : Q in program of your work is 209
