I bought an electric blanket which turns on (led lights up) but doesn't seem to be producing heat. And if it is, its very low. The label says it 40w.
I watched this video on YouTube on the same thing and followed his findings. His ones don't turn on at all but mine does.
Not sure what the SMDs which says M7 are.
Not sure what else to check. I'm confused how it can be drawing 44 watts yet no heat is being output!
Help appreciated as its winter now!
- Its drawing power from the wall at 44 watts on highest setting number 3. Number 2 is 24w and 1 is 11w.
- I opened up the controller and checked the fuse (black box component next to neutral) which is fine. Led wouldn't light if it wasn't anyway.
- Checked the thermo fuse in between the resistors which seems fine.
- The blanket itself reads same ohm measurements as the guy in the video. 12773Ohm on one set of pins, and 2555Ohm on another set.
- The 2 big resistors values seems correct at 1800 Ohm each.
- The 563 SMDs are reading as 56kOhm.
