Which is not what the TS is looking for. He is looking for 0-20V into high imoedance. The specs say it can do that. They may be lying, but I would not assume so.I do not know if a generator that outputs +/-20V into a 50 ohm load.
Yes BobTPH what i'm looking for is a generator driving its output (High Impedance) from 0 to 20V sine wave (or square wave). The max frequency: 200KHz is ok (not critical).Which is not what the TS is looking for. He is looking for 0-20V into high imoedance. The specs say it can do that. They may be lying, but I would not assume so.
No, I checked SDG1032X but not other models.....maybe a job for today as need to PD check more before shipping them out.My budget is in order for a the Siglent you quote. But, these Sigilent can produce a 20Vpp wave with an offset of 10V ? As in the attached picture ?
In English, we say run-of-the-mill or plain vanilla, meaning ordinary (italiano: ordinaria/ordianrio)Mill device: understood.
Just won't let you enter the parameter, or adjusts other parameters to fit...So basically output is limited to ±10V? Their specs are grossly misleading then.
What does it do when you exceed the limit, clip?
Thank You very much for your check. So, if I'd like to get a wave as the following, i need to put an extra circuits like an active clamper, that shifts the 10Vpp output of the function generator, to a 10Vpp + 10V ?OK, I'm sad to say the Sigilent SDG1032X, or at least my 2y old one, can't do 20vp-p with a 10v offset.It's output is limited to 20v pp max, or 10v p-p with a 5v offset
Something like this one ?Shifting the output is easy...
Any good rail-to-rail opamp with a 24v supply will do it, or a single BJT
Possibly if it can be adapted. That says unity gain which implies a voltage follower or an inverting configuration whereas my example is non-inverting and a gain of 2.
A sine wave of 200KHz. The image of the amplifier shows a potentiometer (it seems a potentiometer) so i hope it has some kind of control on the gain. But the product has no specs or technical detail. And no feedback from users.Possibly if it can be adapted. That says unity gain which implies a voltage follower or an inverting configuration whereas my example is non-inverting and a gain of 2.
Better to find an opamp in a DIP package that can easily be soldered on some stripboard. What frequency range, and only sine waves or others as well?
Very beautiful, i like it. The only problem is the space it takes up. That is the wave i am looking for.I have this monstrosity, Global Specialties 9004 combination signal generator, RF generator, frequency counter and power supply.
Shown generating a 20Vpp sine at 1Mhz with 10V offset. It clips if I go any higher on either amplitude or offset.
