Siemens Statotherm alternative
Mulo_g
Joined May 23, 2021
I am a newbie. On one of my machines has a siemens Statotherm heater controller that has gone bad. Its function is to intermittently on and off a contactor that supplies power to a heater. There is a dial to control on off time or heat. There is no input feedback.
What type of controller is it called. Any alternative? I tried thyristor controller. But I will have to change wiring and bypass contactor.
LowQCab
Joined Nov 6, 2012
5,101
Contact Siemens,
there is a small chance that they may replace the unit for free.
Or, you can simply purchase a new one.
Since you provided no other information,
excepting that, you don't want to change any wiring,
those are the only suggestions that can be made here.
Mulo_g
Joined May 23, 2021
Contact Siemens,
Thank you sir. Its very old, 1090. Can't find anywhere on net. Obviously even siemens wouldn't have it, nor would be interested
LowQCab
Joined Nov 6, 2012
5,101
The phone call to Siemens is free,
You never know what kind of valuable info you might get.
There are also Commercial Repair Companies
advertising Repairs on this unit on the Internet.
Personally, I would gut the existing chassis and replace
everything inside with my own Circuit-Design and Components.
It's not likely to require a complex Circuit, and the parts are cheap.
Mulo_g
Joined May 23, 2021
Thanks,
I bought 2 replacement controllers. One thyristor based. other, bimetal. I think bimetal one will work with existing circuit with contactor.
