Short circuit in PWM led dimmer with 555 & pot
outro
Joined Mar 7, 2017
43
Hi outro,
If you lay out your board properly on your donnut perfboard, it should look something as below...
Allen
Hello abs,
thanks for your reply.
I am running out of capacitors, well, I only have the ceramic/plastic capacitors which came with the Arduino Starter Kit (0.01uF?) but I have quite many electrolytic capacitors which are of much higher value. What is the 'real' function of the capacitors in this circuit? Can I replace them?
I am quite new to electronics, and I see a lot of capacitors used in different circuits, but rarely any explanation.
I have read obviously about how they work and are used for - they save energy and release it, but I don't seem to get my head around the use in the circuits.
(short: what caps doing in this circuit? can I replace with bigger?)
outro
Joined Mar 7, 2017
43
Okay, now I'm at a point where it works ONLY if I touch the potentiometers rotating part (where u tune it) ? Confusing!
