shorcut protection in a variable witching power supply
Rufinus
Joined Apr 29, 2020
324
Hello.
I have a variable witching power supply 0-36V and 15Amps. I´d like to add an electronic protection against shortcuts. I have seen some in internet but they are rated for a fixed voltage. Is there any option to use between 0-36 volts?
Thank you
dl324
Joined Mar 30, 2015
18,471
I don't see why they'd be dependent on voltage. You can make your own using a current sense resistor, a comparator, and a P channel MOSFET. The downside is that you're going to affect voltage regulation unless you can put the sense circuitry before the regulated output.
Rufinus
Joined Apr 29, 2020
324
No.
But no problem. I understand it is not possible to do it whitout that information, so I´ll just be careful.
Thank you for your help and interest!
Ya’akov
Joined Jan 27, 2019
10,303
Hello.
Thank you
Just for the record, you want switching and short circuit instead of "witching" and "shortcut".
I managed not to make some sort of terrible pun. I hope that people appreciate that.
Rufinus
Joined Apr 29, 2020
324
hahahaha.
I´m sorry. I´m still learning english
A fuse is a good protection? I mean, is it fast enough to protect the power supply?
Ian0
Joined Aug 7, 2020
13,280
That's a bit of an unknown quantity - it depends on how the power supply works.
If it's a current-mode design, it will have some inherent current limiting. A voltage-mode design might not do so well.
I don't think anyone would sell a bench power supply with no over-current protection whatsoever.
