Shocking myself...
SLK001
Joined Nov 29, 2011
1,549
Embrace the shock. It shows that you are still alive! After many years of fixing the older tube TVs, baby shocks like these don't even faze me any more.
#12
Joined Nov 30, 2010
18,224
My first 40 hour job was on 27KV TV's but those chronic static shocks are irritating to the point that you become angry with yourself every time you forget to ground out the charge properly.:mad: It's just a darn nuisance, and it comes and goes with the weather, so you have to keep changing your habits from day to day.
It was easier in Southern California where static is a constant. You develop behavior patterns and they work consistently.
AnalogKid
Joined Aug 1, 2013
12,290
An old solution is to touch things with a key. The energy transfer is the same, but the key acts as a contact surface area multiplier.
You can buy certified ($$$) anti-static coating in a bottle; you wipe it on the work surface with a rag. Diluted Downy works just as well (people actually tested this in the 70's). There still has to be a contact point for a wire or path to earth ground, but that is a constant in all surface management.
ak
DickCappels
Joined Aug 21, 2008
10,661
I will order some smoke detectors to be sent to my brother's house in the U.S. to the carried to me next month as a source of Americium so I can play with ionization chamber ideas. Without ionizing radiation, it will be difficult to tell whether it is working or just leaky.
ian field
Joined Oct 27, 2012
6,536
A few years back - a local pharmacy shop was offloading ionisation smoke detectors at £1.99. They weren't much good, but the battery was worth what I paid, and I got a red LED + PP3 battery snap into the bargain.
ian field
Joined Oct 27, 2012
6,536
ak
An anecdote about a service engineer repeatedly called out to a copy machine that kept giving people shocks;
It was on a table in the middle of a large carpeted office..................
ian field
Joined Oct 27, 2012
6,536
There may be more than one, but the one that I'm familiar with is Am-241. IIRC (from 25 years ago) it's a pretty hot source at about 1 μCi
Seems most of its radiation is Alpha - which was the type suggested.
There's a clue in the name - "ionisation chamber".
DickCappels
Joined Aug 21, 2008
10,661
The nice thing about Alpha particles is that they rarely penetrate a sheet of paper, let along your skin. It may be the tamest ionization radiation source available.
